How to model PFC welded to bottom flange of UB (i.e compound member)
Joe_Hughes
Joe_Hughes
Hi, as per the attached mark-up, how can I model a PFC member welded to the bottom flange of an UB member.
Context: I have modelled an existing roof truss in Robot, and the analysis shows the rafter to fail in bending under revised loading conditions. Therefore I'm proposing to stiffen the rafter by welding a PFC as explained.
Thanks.
kevinj.888
@Joe_Hughes Perhaps you can try to create a custom section.
Go to Tools - Section Definition
Open 'Section Database' look at Item C20.
If this doesn't allow you to add PFC only on one side, then you can always create the two item independently
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Joe_Hughes
Use Tools >Section definition module.
Refer to video
Krzysztof Wasik
