How to merge dead and live loads with a point load combination in results
Message 1 of 12
Hi, just another quick query, I have added dead loads and live loads in a combination table. But my point load is not showing unless I change it in the box above, but then it will only show the point load. Please help
Replies (11)
Message 2 of 12
Message 3 of 12
thank you for the reply, on the image its 173.01 that's with no point load calculated. Should the 173.01 not be more? to show the point load?
Message 4 of 12
Message 5 of 12
Its like when I select 1.35DL +1.5LL I get that load, but when I select LL2 I only get the point load. Is there a way of showing them both calculated together?
Message 6 of 12
Could you attached the model, please?
Message 7 of 12
Thank you, much appreciated
Message 8 of 12
You have 3 load case:
1. DL1
2. LL1 (continuous).
3. LL2 - with point load.
The combination load (number 4) has DL1 and LL1 (continuous loading) - that's why you didn't see the point load influence from LL2 on moment diagram.
Message 9 of 12
DP_IL is there a way I can rectify this? Do I delete LL2 & add the point load to LL1?
Message 10 of 12
You can add LL2 to combination. The same as you did with other case.
Different way is to add point load to case LL1.
Message 11 of 12
One final thing sorry, can you help me get this in a -50 point load to add to this formula. I just cant seem to get it to work
Message 12 of 12
As I see, you have already added the point load with load factor 1.0 (is it as you want?).
Here's the results from this combinations for moments:
Are the same as yours?
