How to export all visible bar results to dwg?
dawid.deptula
dawid.deptula
I have problem with export all results with forces for each point on bar. When my view is close to element, every result value is shown, but when I export view is showing only a few values. How to export results with every value for each point to dwg?
Results on bar (I see each value):
After export to dwg I want to see every value on bars:
But I get sth like this. In dwg misses many values (text objects):
Stephane.kapetanovic
hi @dawid.deptula
you can test a result type here.
rather than all, you can choose local or global extremes
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
dawid.deptula
Thanks for hint, but it doesn't solve my problem. Still can't export all values.
hi @dawid.deptula
do it by API
Best regards
