How to display table of "Geometrical objects" coordinates?
andrew.fraserVBHU4
andrew.fraserVBHU4
If you have a set of "Geometrical objects" defined in RSA, e.g. lines, is it possible to view a table of all of these in order to check, or modify, their coordinates?
I know that it can be done on a object by object basis but have not been able to find a way to display a table of all such objects.
One reason I ask is that having used the Planar Symmetry option to reflect a number of my lines I see that a number of lines are one or two millimeters out in the z-axis of my story plane so would like to do a global check.
Stephane.kapetanovic
HI @andrew.fraserVBHU4
You will be able to find a good number of topics dealing with the geometry of the panels on the forum and the programs to edit and correct the coordinates.
Panel contour points modification (API)Rounding up coordinates (API)VBA Excel macro for any object geometry modifications (API)
Your question should be more general and concern the edition and checks of surface objects using an inspector allowing you to visualize their geometry also with regard to other objects, bars and nodes. Finally, edit a report with captures that you could launch before your calculations while you go for coffee with your colleagues and objectify yourself after the break.
It is possible to solve the need for more reliable precision by easier modeling. Apps exist on the store. You can get there with this link.
https://apps.autodesk.com/RSA/en/List/Search?facet=__category%3A%3AStructural%20Modelling
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
