HOW TO DESIGN A FOOTING UNDER THREE COLUMNS, OR (MORE THAN TWO).
Message 1 of 10
By default, ROBOT SA can design footing under 1 column or 2 at maximum, my question is how to design footing under 3 or more columns especially when we send the revit model to robot structure analysis,as in the picture i have some of the footings under three and four columns.
Replies (9)
Message 2 of 10
Simau
Hi @Anonymous
you may use panels with thickness with foundation parameters
Example model attached
M. Agayr
Message 3 of 10
i have model the structure in revit, now for analysis i have send it to robot rsa, but as i select the nodes to for the analysis, message poped up that do you want to design the footing for 2 columns, my question is why it doesnt appear for 3 or more columns? what should i do to design the footing under 4 columns, i have attached the rtd file, if any 1 know kindly answer it.
Message 4 of 10
Simau
Unfortunately no more than 2 columns
M. Agayr
Message 5 of 10
In this case i'd consider using my own excel sheet than the design module of RSAP.
Message 6 of 10
rb_s-90-k
yes that is how i would do it
Message 7 of 10
yesterday55555
You may also use thickness and turn on the parameter of foundationsFOTTING.PNG
Message 8 of 10
What formula do you use to compute for Kz of foundation you input in RSAP? Wrinkler or something else?
Message 9 of 10
yesterday55555
for Kz, I follow Wrinkler
Message 10 of 10
So you do Qa/delta? I use the Vesic one and it has almost half of what Wrinkler gives.
