How to design a chimney with round opening on it
TSOFA
TSOFA
Hi to all,
I want to design a 30m tall steel chimney that has a round opening on the surface in order to be able to connect with a pipe of 1.41m diameter. I see that there are some relative posts but I couldn't find one that the opening has round shape. I am attaching the relative file
Thank you in advance
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @TSOFA
You can use this approach:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
TSOFA
Thank you very much for your tutorial video, it was very helpful! I did all that you show at your video, but when I try to extrude the upper contour of the shell in order to model the rest of the chimney (height 5-30m), it doesn't seems possible. Robot just doesn't do anything.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @TSOFA
If you have the same thickness along the entire height  just create a 'longer' chimney (up to 30 m) as a one 'tube'. Otherwise create a new circle and extrude it and them make sure the meshes are coherent.
Artur Kosakowski
TSOFA
My chimney has not the same thickness along the whole height, so I created a circle and then I extruded it. What is the best way to make sure the meshes are coherent? I am attaching a print screen of my mesh.
TSOFA
I tried to model the base plate of the chimney and the mesh is not correct. Can you help?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @TSOFA
You need to match the mesh sizes:
Artur Kosakowski
