How to create thin walled sections??
Message 1 of 44
When i create a thin walled section in section definition, it is analysed like a solid section in the steel design module. (please see picture attached). Does i have to "check some box" to make it a real thin walled section that can be analysed has it should be?
Thanks in advance!
Cheers!
Replies (43)
Message 41 of 44
Hey Artur, I'm trying what you proposed, my question is: when i change de dimensiona, "h" and "B" of the sections database, I will have to calculate all the propieties: Ix, Iy, Wx, Wy, S, kg/m?
Message 42 of 44
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Yes, when you change the size of a section you need to recalculate its properties.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 43 of 44
stroxy
Hi Artur
I can't seem to find a database with an editable omega thin walled section as you have suggested.  Could you please recommend one?
Message 44 of 44
nakhwahuzaifa
Community Visitor
Community Visitor
Wher do i paste it to get the the section
