How to create steel fabrication drawings in RSA program ( note or video)?
In case steel structure design.
After analysis and design to completed.
how to do the  drawing procedure in RSA program ( note or video).
@Anonymous Artur Kosakowski edited the topic for better findability and marked post as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Do you mean shop-work/fabrication drawings?
Artur Kosakowski
hi Artur.Kosakowski
yes I mean shop-work/fabrication drawings
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
RSA being a structural package is not the tool for such task which in Autodesk portfolio is the job of Advance Steel
You can export your Robot model to AS using the link between these two programs (check: https://forums.autodesk.com/t5/robot-structural-analysis-forum/robot-2-advance-steel-link/td-p/57556...)
You can learn how it works watching the recording of the 11th Robot webinar available from here .
Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I just wanted to make sure that I managed to describe the intended workflow for design to steel fabrication. Is there anything that still needs further clarification?
Artur Kosakowski
