How to check if wind load wil cause oscillation
2 REPLIES 2
544 Views, 2 Replies
I have a tall and thin concrete structure and I want to check whether wind load will cause oscillation issues. I have run modal analysis, identified the modes where the mass participation is high and checked the deflected shapes, so I think I know the natural frequency of the structure for movement in each direction.
How can I tell if the wind load will be an issue? How can the software calculate the forced frequency from the wind so I can check if this is close to the natural frequency, hence causing a problem?
thanks
2 REPLIES 2
Rafacascudo
Time history analysis will check if structure is prone to ressonance when submitted to a syntetic wind function.
But it's your(user) job to create this wind function based on a code or on academic papers/books
Rafael Medeiros
in reply to: Rafacascudo
Thanks. I was hoping it'd be easier than this.
