HOW TO CHANGE REBAR DIAMETERS FROM AMERICAN TO SI UNITS
Please i need the procedure for changing the rebar sizes from #3 #4 #5 #6 etc..... into 8mm 10mm 12mm 14mm 16mm....etc
Any Help?
HoshangMustafa
Hi
Go to Tools> Job preferences
Please find the attached file
Hello again,
I have tried to change to metric from job preferences but after recalculating the panels the rebars keep coming as american units.
Do i have to be starting the project from scratch for it to be changed?
Hello again,
Artur.Kosakowski
Autodesk Support
Autodesk Support
Check if your default reinforcement bars database is ACI metric rather than ACI:
Artur Kosakowski
marcabdallah95
@Anonymous after you select aci metric in the database and run the calculations again the # of rebars shoukd adjust to soft metric units #13/#16...
If not, you shoukd save your work, close it and open it again and make sure the metric database is selected.
