How to assign steel design parameters to many (selected) bars at the same time
I'm struggling with definitions number. How could I select multiple bars (numbers) and set parameters all at once!?
Regards!
@Anonymous Artur Kosakowski edited the topic from 'Deign' for better findability and marked the post as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
See: https://forums.autodesk.com/t5/robot-structural-analysis-forum/change-code-group-parameters-for-sele...
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
