Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
How is the maximum normal stresses (Smax) calculated in robot?
5 REPLIES 5
rbaXBU6W
1017 Views, 5 Replies
Hi
Does anyone know how the maximum normal stresses is calculated in RSA?
5 REPLIES 5
Refaat
in reply to: rbaXBU6W
Hi@rbaXBU6W
Maximum normal stresses are a sum of stresses resulting from axial force and bending. Stresses
rbaXBU6W
in reply to: Refaat
@Refaat
The maximum stresses may not exceed the yield strength, right? If the materiale is steel...
Krzysztof_Wasik
Hi   @rbaXBU6W
Maximum stress can exceed yield stress in linear static analysis
Krzysztof Wasik
rbaXBU6W
in reply to: Krzysztof_Wasik
Hi @Krzysztof_Wasik
Yes, i know that the maximum stresses can exceed the yield strenght. My question was more in the designing phase. What do you compare the maximum stresses to in the designing phase. This must be the yield strenght of steel, if the material is steel?
Krzysztof_Wasik
Hi @ @rbaXBU6W
In design phase (for steel members ) code based formula are used in Steel Design module. Yield stress is one of the checked criteria. Others are buckling, lateral buckling, stebility, depending on used code and member section.
Krzysztof Wasik
