How can I import accelerograms?
Hallo,
how it is possible to import accelerograms in Time History Analysis? Of course, I have done a modal analysis first but it can't read the accelerograms. Is there any step-by-step?
I have attached 2 accelerograms.
Thanks in advance.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
You need to correct thf file first
- delete  duplicated entries for 0 point
- correct number of lines
- replace commas by dots
Rafal Gaweda
Thank you so much for your help... Now the problem is that I have 3 pairs of accelerograms (directions X1,Y1,X2,Y2,X3,Y3) that i must import in THA and i must use combinations of them: G+0.3Q+X1+Y1, G+0.3Q+X2+Y2, G+0.3Q+X3+Y3. So what is the right way to do it?
Thanks in advance.
