How can I correctly apply imposed displacement and then find the moment force it produced?
yiviw97057
yiviw97057
I want to push the outer part down 5mm to see how much moment force reaction I get on the other end that is fixed, but I get this error, is there something I am doing wrong?
The other end is fixed, and I want to see the total moment reaction forces I get. Do I go into results - reactions and then look at the sum of all the nodes for MX?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @yiviw97057
Imposed displacement /rotation can be defined only in the node supported in direction for which imposed displacement is defined. Define supports in UZ direction in nodes with imposed displacement defined.
Krzysztof Wasik
