Hollow Sections Column-Beam Connections
Helo,
here, when I select Design- steel connection design, I enter the connections. here when I select new connection such as frame knee - column beam etc. But when I try to define any connection, I can define them for I section only. I want to define them for hollow rectangular and hollow circular sections. can you help?
2) here also i cant find T joint option for beams in a same plane, i.e. beam to beam connection T joint.
Kindly help.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Only I sections are currently supported.
Is this the connection type you need?
Artur Kosakowski
   I don't think that there is any National Code that covers these type of connection (except maybe Japanese)  but I could recommend an alternative solution.
Would you like
Frame Knee Connection ,
1.   Column (SHS or RHS) and Beam (SHS or RHS)  or
2.   Column (SHS or RHS) and Beam (IPE or HEA)
I suggest IPE,HEA     for beam
