Hollow section connections according to Eurocode
Hello!
I wonder if it is possible to do the connection check presented in SS-EN 1993-1-8 Chapter 7, check of hollow section connections in RSA 2015.
Is the check done by RSA, if so, how do I extract a presentable result from it?
Regards.
Artur.Kosakowski
Autodesk Support
Autodesk Support
I hope that in the SS the chapters are is the same as in the general EC3. If so, you can design K, KT, N, T, X and Y joints and teh results are presented in
their calculation notes.
Artur Kosakowski
Marvelous. Although, since I started with hand calculations, I'll keep to them this time. But it is nice to know that the feature is available.
SS-EN 1993-1-1 is EC3. SS-EN 1993-1-8 is the subpart concearning connections 😃 So they should be quite the same!
Thanks a ton!
