Help with combinations using CM66 (France)
anacffaria
anacffaria
I'm doing a model with norms NV65 and CM66.
When I do automatic combinations, a value for "Extreme Snow Coefficient" shows up, and I don't understand what it's for, how it might impact the results and the meaning behing it. Can someone please explain it to me?
See the attached image to clarify.
Thank you in advance,
Ana
Simau
Hi @anacffaria
Combination is :  G + 1xVent ext + 0.5xNeige ext + SigmaQi
If you haven't created a Neige extr load case robot will use 0.5x1.667xNeige
If you have created a Neige extreme from table below, Robot will use 0.5xNeige extreme
M. Agayr
anacffaria
Thanks for explaining!
