Heavy model, slow operation
Hello, I'm currently designing a steel framed building. The model is made up from 403 bars, 4 slab panels, and 996 nodes after meshing. I have 35 analysis cases, which include 1 modal case and 2 spectral analysis cases. The problem i'm hvaing is that my model file is extremely heavy (around 800MB) which is quite unsual, and in consequence, the model is extremely slow when I try to visualize results or when I try to modify anything.
Why is this happening?
Rafal.Gaweda
Autodesk Support
Autodesk Support
File please.
Rafal Gaweda
It's pretty heavy so you have to be patient :P.
http://www.4shared.com/file/LWgyMPvA/622-01-01-001_0A_1320.html
Thank you for your assistance.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Open file in repair mode.
Additionally: please activate saving results on exteral file or at least save them in such way when program asks.
Save file from time to time using "save as" under new file name.
Rafal Gaweda
Thank you. Worked perfectly.
