Harmonic load moving at a constant velocity
karolis_sakalauskas
Observer
karolis_sakalauskas
Observer
Observer
I am trying to check the comfort criteria (maximum accelerations) for a multi-span continuous pedestrian bridge. The loading model is a harmonic load (F0*cos(wt+phi))moving at a constant velocity (v) along the bridge. I would like to ask, if it is possible to perform this type of analysis on Robot Structural Analysis and how?
Thanks in advance
Rafacascudo
Just curious,
What kind of vehicle/machine is that and which is its velocity
What is the frequency?
Rafael Medeiros
Stephane.kapetanovic
karolis_sakalauskas
Observer
Observer
The load represents a person walking/running along the bridge. The amplitude of the load (F0) is equal to 0.18 kN. The walking/runnung frequency corredponds to the 1st mode of the bridge. The size of the step is 0.7 meters.
karolis_sakalauskas
Observer
Observer
Thank you for your answer. I have also found a useful video which also analyses the similar problem regarding moving harmonic load using time history analysis. It starts from 31:22.
The video link:
https://youtu.be/fRnmamjZbUw?si=CAllUnlOQOf-_EI6
