Announcements
Ground bearing Slab reinforcement
ali.alheneiti
ali.alheneiti
I have a raft foundation supported by elastic springs, I am trying to design it in Robot according to EN 1992, the slab has gravity loads, wind, seismic, and temperature. When I designed it for simple bending, the maps are similar to the bending moments maps, however, when I designed with bending tens/comp: I get the following maps, where the top and bottom reinforcement are the same, which shouldn't be the same:
I know that this is mainly because if this requirement per Eurocode:
So, If I disable this option, does that mean, that Robot, doesn't calculate the min reinforcement with regards to tension and compression?!
-There is a big difference when I check this option and when I uncheck it.
Please help
ali.alheneiti
Hello everyone,
I posted this question before and nobody answered me, hopefully, this time I can get an answer.
I am doing a ground-bearing slab on elastic springs in Robot, and when I design it using the required reinforcement in Robot, I have to define the reinforcement parameters with the following options to choose the minimum reinforcement according to Eurocode 2:
So, the problem that I am facing is the reinforcement maps, the top and the bottom are the same (Which should not be the case), however when I select "Disable SLS condition 7.3.2 (2), I get normal results (where the top and the bottom are different), and I found out that the minimum reinforcement is governing the design based on the tensile axial forces and it will be calculated according 7.3.2 (2) for pure tension.
My question, If I disable this option, does that mean that Robot does not take the axial stress into consideration in the crack width and the required reinforcements?!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
