Getting and Updating thickness and thickness' name
Hello to everybody!
I would like to get and updating in excel thickness and thickness'name from the object selected.
I'm struggling with the following code:
To get both values:
Public Sub CommandButton1_Click()
Set RobApp = New RobotApplication
Dim RSelection As RobotSelection
Set RSelection = RobApp.Project.Structure.Selections.Get(I_OT_OBJECT)
Dim Obj As RobotObjObject
RSelection.ExcludeText Bsel
Dim MatLabel As RobotLabel
Dim MatData As RobotMaterialData
Dim THData As RobotThicknessData
Dim HomoThickData As RobotThicknessHomoData
 Set Obj = RobApp.Project.Structure.Objects.Get(AllObjects.Get(ii).Number)
With Range("b5:c6")
.Clear
.NumberFormat = "#0.0#0"
End With
Cells(5, 2) = "1000"
  If Obj.Main.GetGeometry.Type = I_GOT_CONTOUR Then
    Row = 6
                    Set THData = Obj.GetLabel(I_LT_PANEL_THICKNESS).Data
                If (THData.ThicknessType = I_TT_HOMOGENEOUS) Then
                        Set HomoThickData = THData.Data
                        If (HomoThickData.Type = I_THT_CONSTANT) Then
                        Cells(Row, 2) = HomoThickData.ThickConst * 1000
                       Next ii
         Dim MatCol As RobotLabelCollection
    Set MatCol = RobApp.Project.Structure.Labels.GetMany(I_LT_MATERIAL)
    Row = 7
    For I = 1 To MatCol.Count
        Cells(Row, 2) = MatCol.Get(I).Name
        Set MatLabel = MatCol.Get(I)
        Set MatData = MatLabel.Data
    Next I
End Sub
to update:
Private Sub Button3_Click()
If Not RobApp.Visible Then
    Set RobApp = Nothing
    MsgBox "Robot closed", vbOKOnly, "ERROR"
    Exit Sub
Else
RobApp.Interactive = False
    If (RobApp.Project.Type <> I_PT_PLATE) And (RobApp.Project.Type <> I_PT_SHELL) And (RobApp.Project.Type <> I_PT_BUILDING) Then
        MsgBox "Structure Type should be PLATE or SHELL", vbOKOnly, "ERROR"
        RobApp.Interactive = True
        Exit Sub
Dim Row As Integer
Dim Iter As Integer
Dim ObjNumber As Integer
Dim RNAM As RobotNamesArray
Set RNAM = RobApp.Project.Structure.Labels.GetAvailableNames(I_LT_MATERIAL)
Dim MATExist As Boolean
Dim ChangeName As Boolean
Dim THLabel As RobotLabel
THExist = False
MATExist = False
Row = 6
If THExist Then
Set THLabel = Obj.GetLabel(I_LT_PANEL_THICKNESS)
Set THData = THLabel.Data
                            If Not IsNumeric(Cells(Row, 2)) Then
                                MsgBox ("There is no numeric value in Cell(" + Str(Row) + "," + "C). Update aborted")
                                Exit Sub
                            If (HomoThickData.ThickConst <> CDbl(Cells(Row, 2))) Then
                                If MsgBox("Defined thickness in label " + THName + " is " + Str(HomoThickData.ThickConst) + _
                                 "." + vbNewLine + " Replace it by " + Str(Cells(Row, 2)) + "?", vbYesNo) = vbYes Then HomoThickData.ThickConst = Cells(Row, 2).Value / 1000
                            MATName = Cells(Row, 3).Value
                            For IMat = 1 To RNAM.Count
                                If (MATName = RNAM.Get(IMat)) Then
                                    MATExist = True
                                    Exit For
                            Next IMat
                            If (MATExist) Then
                                If (THData.MaterialName <> Cells(Row, 3).Value) Then
                                If MsgBox("Defined material in label " + THName + " is " + THData.MaterialName + _
                                 "." + vbNewLine + " Replace it by " + MATName + "?", vbYesNo) = vbYes Then THData.MaterialName = MATName
                            Else
                                MsgBox "Material " + MATName + " does not exist in model. It will not be assinged to panel thickness"
                            RobApp.Project.Structure.Labels.Store THLabel
                        Else
                            MsgBox ("Panel thickess label " + THName + " is not homogenuos thickness label." + vbNewLine + _
                                    "It will not be updated")
                Obj.SetLabel I_LT_PANEL_THICKNESS, THName
            Else
                    MsgBox ("There is no numeric value in Cell(" + Str(Row + 1) + "," + "C). Update aborted")
                    Exit Sub
                            MATExist = True
                            Exit For
                    Next IMat
                If (MATExist) Then
                    Set THLabel = RobApp.Project.Structure.Labels.Create(I_LT_PANEL_THICKNESS, THName)
                    HomoThickData.ThickConst = CDbl(Cells(Row, 2).Value / 1000)
                Else
                    MsgBox "Material " + MATName + " does not exist in model. It will not be assinged to panel thickness." + vbNewLine + _
                            "Panel thickness " + THName + " will not be created and assigned to panel"
End Sub
 maybe just @Rafal.Gaweda  could help me!
