Geometry from AutoCAD 3D to Robot
Message 1 of 11
Hello everyone,
I have some problem concerning AutoCAD 3D drawing. I would like to move construction made in AutoCAD 3D to Robot but in some way it is impossible. I save .dwg file as .dxf file and then open it in Robot, but instead of construction there appear some bars in various places. So my question is, how should I import 3D drawing to Robot?
Part of construction in .dwg file http://www.sendspace.com/file/htukth
Replies (10)
Message 2 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
SHould these bars be considered as panels or bar elements?
Rafal Gaweda
Message 3 of 11
Bar elements.
Thanks for your reply.
Message 4 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
To clarify: 3d solids can be imported to robot after saving them as sat file and activating ACIS in robot. But in  such case every side of such object will be imported as panel. So for design purposes it will be useless.
So , import as bars then create bars in corect positions basing on imported ones or create bar model from scratch in Robot.
To import 3D model you should create such model either in ASD Steel or in Revit
Rafal Gaweda
Message 5 of 11
I see it's not an easy way.
Could You explain me how to do it?
Message 6 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
justPosite wrote:
Bar elements.
My way, example: http://screencast.com/t/oSBWOBjGPe2p
Rafal Gaweda
Message 7 of 11
Thank you for your time,
Your example concerns only Robot, but I would be grateful if You could show me how to obtain this form in Robot.
Message 8 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
To moze po polsku bedzie prosciej jak Pan wyjasni o co chodzi.
Rafal Gaweda
Message 9 of 11
Pewnie, że będzie prościej. Więc wiem już, że nie można utworzyć z tego modelu konstrukcji prętowej w Robocie. W takim razie jak zapisać to do pliku .sat i otworzyć w Robocie aby otrzymać panele? Wydaje się być proste ale nie mogę tego znaleźć.
Dziękuję za odpowiedź.
Message 10 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Operacja moze zakonczyc sie polowicznym sukcesem poniewaz czasami pojawia sie blad przypisywania materialu na panele ACISowe w robocie.
Ale procedura wyglada tak:
- acad: file \ export \ wybrac *.sat, wybrac elementy, zapisac
- robot : wlaczyc typ struktury powloka, ustawic poprawne jednostki, uaktywnic ACISa http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Autocad-dwg-files-import/m-p/3181550/highlig... , wczytac plik sat
Rafal Gaweda
Message 11 of 11
Działa, dziękuję za poświęcony czas.
