Generate EC wind loads by API
I am trying to understand how to generate Eurocodes wind loads by API.
This how I proceed:
First I configure the project prefs
ProjectPrefs.SetActiveCode(IRobotCodeType.I_CT_SNOW_WIND_LOADS, "NF-EN 1991-1-3/4/NA:2007/2008")
Then I generate the loads
        Dim SWCodeParams As RobotSWCodeECParams
        Dim SWCombEngine As RobotSnowWindEngine
        SWCombEngine = str.Cases.SnowWindEngine
        SWCodeParams = SWCombEngine.CodeParams
        SWCodeParams.StructureAge = 2
        SWCombEngine.Params.TotalDepth = 15
        SWCombEngine.Params.BaySpacing = 5
        SWCombEngine.Generate()
I don't see how to configure SWCombEngine with SWCodeParams.
Your help would be very appreciated. Thanks in advance.
Francois
Replies (7)
Rafal.Gaweda
Autodesk Support
Autodesk Support
Code names are listed in this file:
"c:\Users\All Users\Autodesk\Structural\Common Data\2013\Data\Other\norms.xls"
so correct line should be like that:
ProjectPrefs.SetActiveCode(IRobotCodeType.I_CT_SNOW_WIND_LOADS, "EC1 - French NAD")
Rafal Gaweda
Ok for that but it does not change anything.
I would like to change programmatically the parameters of eurocodes wind and snow loads genereation.
If I do
        SWCombEngine.CodeParams.WindCd = 1.5
        MsgBox("WindCd " + SWCombEngine.CodeParams.WindCd.ToString)
WindCd value still remains unchanged to 1.
Maybe this cannot be done by API.
Francois
Rafal.Gaweda
Autodesk Support
Autodesk Support
Unfortunately you are right. Due to bug in API you can not set Params, Codeparams for SW generator.
You can only get them. I will register it for correction.
Rafal Gaweda
Great, I was struggling since 2 days on it to find a solution. Do you think it can be implemented in the next update of Robot?
Again thanks for your help, I think I will have more questions in the future.
Francois
Rafal.Gaweda
Autodesk Support
Autodesk Support
workaround : RobApp.Project.Structure.Cases.SnowWindEngine.ShowParamsDlg()
then enter these values manually in the window
Rafal Gaweda
I've just started working with API Robot and I've been blocked in this part. I use the Autodesk Robot 14. By these codes I can only change the parameters such as "Depth of Structure" and "Bay Spacing" but I can't change the code parameters (Eurocode 1 in my case) such as "Structure Age", "Altitude" etc. You've answered in last posts that there is a bug which prevent this processus. I would like to know if this problem and this bug has been resolved in Autodesk Robot 14 or 15?
Thank you in advance for your answer
Goodarz
xblanchet
After 7 years, has the problem been solved ?
I have the same problem with my script.
regards,
