Foundation Sliding error
benofwono
benofwono
Hi @Artur.Kosakowski,
I am getting a "condition not met for foundation sliding" error when designing the foundation under the shear wall.  It is sort of not settling on an A value for the strip. What could be the problem?
See attached the calculation note.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @benofwono
Could you attach the Robot file and indicate the foundation to look at?
Artur Kosakowski
benofwono
I think the problem was in how far below the ground level is the strip located. Seems to correct the error when I adjusted the figure from 1 to 1.5m
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @benofwono
Thank you for posting this information.
Artur Kosakowski
