Foundation creating
Foundation creating
Message 1 of 9
Foundation creating
I 've modeled a steel frame structure and i want to add continuous footing foundation to it.
How is this possible? Is there a way to create it and appear on my model? And as for the loads, is there a way to get the loads from the building automatically or should i do it manually?
Replies (8)
Message 2 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
RC Beam (rectangular, T or upside down T section (T with 180 deg gamma angle)) with Bar Elastic Ground property.
Rafal Gaweda
Message 3 of 9
Thanks a lot for your fast response.
What about an individual footing?
Message 4 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
Ordinary nodal support
Rafal Gaweda
Message 5 of 9
Yeah, but if i want to calculate the reinforcement of the individual footing, then i have to give the loads to it manually?
Message 6 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
No, just select supporting node and import it to RC Footing module.
The same way like for continuous footing.
Rafal Gaweda
Message 7 of 9
Thanks a lot Rafal! 🙂
Message 8 of 9
dimogrec
You can also check here http://www.robotoffice.com/rsa/
there are 2 videos for spread footing and continuous footing
Message 9 of 9
Yeah, found an older post of Rafal aswell with this link http://screencast.com/t/oqzjXKKhND
