Floor, wall and shell elements
Hello all,
I was wondering if there is any difference between a floor and a wall element if they are both modelled as shell elements. I mean, I create the floor panels and set the calculation model as shell, same thing for the shear walls. Is there any difference (in the in-plane or out-of-plane stiffness, in the integration rule, in the shell element used,etc.)?
Also, I would like more information regarding the default shell element used by Robot - number of nodes, number of degrees of freedom for each node, interpolation functions, integration rule, if a reduced stiffness for the shear component is taken into account, etc.
Last question, how is the number of panels in a model influencing the computational burden? I understand the assembly of the stiffness matrix is the most time consuming process, so will reducing the number of panels help making it slightly quicker?
Thank you!
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi
No
http://forums.autodesk.com/t5/robot-structural-analysis/autodesk-robot-verification-and-theory/m-p/3...
Yes.
Rafal Gaweda
