flat slab pinned support modeling
Can anybody help with modelling flat slab on linear supports or explain why occurs negative (sagging) moment at support at Y direction (see below screenshot - moment in Y direction)? Assumed linear pinned support around opening.
Thanks in advance
Alex
teixeiranh
Model please. On the corners it's expected, in the middle depends on the size of your hole and in the size of your FEMesh.
“The most powerful force on the universe is compound interest.”
Subscribe me on Youtube:
https://www.youtube.com/channel/UC6G8OOp318Z1MFzJj5T8uWw
Hi teixeiranh,
Thanks for request. I agree with you about corner moments, I just wondered when I had seen (sagging) moment above support. Model is in attachment.
Alex
Can anybody comment a bit more what to do in such cases? Should I just ignore those moments? I am new in this software and probably there is some mistake in model, can someone just have a quick look on the model?
Alex
Artur.Kosakowski
Autodesk Support
Autodesk Support
Check the shape of deformation first. I think that you may reduce this effect by having denser mesh (more supported nodes along the edge of the opening).
Artur Kosakowski
