Flat slab on pile caps
Hi there all,
I have modelled a basement slab on pile cap foundations. The thicker pile cap panels have been modelled separately and connected to the basement slab panel via rigid links. I have then modelled elastic column supports pinned in the x,y and elastic in the z but free to rotate in all directions. When I run the analysis, I am coming across two problems:
1) At the interface between the pile cap and the the basement slab panel (where the rigid link is) there is a sudden change in moment from positive to negative which doesn't seem right. See below:
2) When I look at the support reactions, I am getting forces in the x and y directions which should not be the case as there is only vertical loads. See below:
Can anyone assist me with these problems?
Tristan
Replies (14)
Rafacascudo
1- When you set direction as " automatic" you have to be sure what are your panels Local directions as Moment selected will be according to these local panel directions. In your case it is better to select cartesian Global X direction and select Myy . Then you can be sure that the moments shown for all panels will be on the same direction.
2- Are the sum of reactions on X and Y direction Zero?
If this doesn´t solve your problem ,can you send the model?
Rafael Medeiros
Hi there Rafael,
Thanks for your response.
1) I have made sure that my panel directions are all the same and match with the global cartesian system.
2) Yes they sum to zero, but still doesn't make sense for there to be horizontal forces when only applying vertical load.
See attached test model.
Kind Regards
Tristan
Rafacascudo
1-Model you sent is different from the picture on your 1st post. Results for Myy look normal to me
2- Horizontal reactions appear because you have 2 levels of slabs . Structure, then, works like a frame where horizontal translation is restricted at the supports.
Of course , if you set the slabs at the same level horizontal reactions will disappear .
Also , due to the different levels ,horizontal forces are acting on both slabs and changing the values of all acting internal forces.
Below compare Myy with the picture above when the slabs are all at the same level
On the model you sent slab and pile caps have the same thickness
Rafael Medeiros
My apologies,
I was not able to share original model.
The main slab was suppose to be TH400. When you set the slab to TH400 and re-analyse. You get the following:
Is this change in moment due to the frame action?
What would you recommend is the more accurate way of modelling this? All slabs at the same level?
Kind Regards
Tristan
Rafacascudo
I would do it at the same level. With this thickness difference , The small 1500mm slabs act almost like a rigid block/fixed support for the 400mm slab . You can test changing their calculation model to rigid body and check that the moments differences on the 400mm are very small.
See moment diagram below
Rafael Medeiros
Great!
Thanks for all the help Rafael!
Kind Regards
Tristan
Rafacascudo
Forgot to say . Always remember to freeze the mesh after you think it is OK. It can save a lot of time during the analysis process
Rafael Medeiros
ledinhchinh0409
hi. @Rafacascudo
Can you attach the model here? Thank you!
Rafacascudo
@ledinhchinh0409   ,  @Anonymous  model is attached on the 3rd message of this thread
Rafael Medeiros
ledinhchinh0409
hi. @Rafacascudo
I want to see the model in message number 6. I don't understand, how to build models for different thickness slabs but in your same elevation. Thanks you very much!
Rafacascudo
model in post 6 is @Anonymous model . It is done with rigid links connecting the different levels panels . It is done in a way that the panels top surface is at the same level.
What I suggested is to model the panels to have its CGs at the same level.
Rafael Medeiros
ledinhchinh0409
Hi. @Rafacascudo
Sorry for mentioning the old topic.
In "webinars" 05,  @Artur.Kosakowski advised to use rigid links to build models with two floors of different levels. I want your answer. Thank you very much.Capture.JPG
marcelgadban08
Community Visitor
Community Visitor
hello everone, i have the same example of a flat slab supported by pilecaps.
my question is since the pilecap is acting as a large foot print for the slab, is there a punching shear that i should check between the slab and the pilecap cap corners? for example, slab thickness is 30 cm, pile cap size is 350cmx350cm. I see that the corners of the pilecap will behave as corners of concrete wall and punching shear should be checked in the slab.
does my thinking make sense?, i would like to hear opinions about this, thanks for your time.
Simau
Hi @marcelgadban08
Punching shear will only be analyzed if there are columns or supports.
M. Agayr
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
