Flat plate
Flat plate
Flat plate
Hi
There is no flat plates in the section data base for me to use as a simple bar?  Also, is there a way I can get them to be tension only?
Derryck
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
For beam you can define arbitrary rectangular section size using Geometry >Properties>Section.
Bar can be defined as tension only using
Geometry >Additional attributes>Advanced bar properties.
Krzysztof Wasik
