Fire Design - HS steel column filled up with concrete
about fire protection... I have hollow section steel columns that are filled up with concrete (no protection in the outer surface). Is it possible to design columns this way in Robot? So in a fire situation concrete basically keeps the temperature of the inner surface of a column lower, and thus increases the time the column can maintain it's strength. Thanks
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Thx Rafal,
Does it matter which encasement type i choose? I mean, isn't there a difference whether the concrete is inside or outside of the profile? it affects the thickness aswell. How can i manage that or does the profile i wish to use determine it (e.g. RH or I-profile)?
Rafal.Gaweda
Autodesk Support
Autodesk Support
Only "outside" is considered in design in Robot.
Rafal Gaweda
