06:03 AM
I am experimenting with calculating a weld using finite elements for a school project.
I access "Plate and shell results", then I select "Table Columns" and for parameters I select "nodes/elements".
Is there a picture somewhere with the meaning of these results? Why are there distributed forces (N/mm) and stresses (MPa) in a node?
What if I select "element centers"? What is the meaning of the results there?
Thank you.
