Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Exporting Robot Structural Model to Revit
6 REPLIES 6
922 Views, 6 Replies
Hi I recently started a project on Robot Structural 2018 but when i was exporting it to Revit 2018 it wouldn't open the Structural Template( as to my limited knowledge thats the original way to import it to Revit)
But then i just to Know that Autodesk has stopped this Structural service of Revit 2018 and onwards
Is there any way that i can successfully import a Robot 2018 model to Revit 2018?
Thnx
6 REPLIES 6
Try opening the Revit Structural template first in Revit (I assume that's the template you are referring to) and then in RSA, go to "Add-Ins"--> "Integration" --> "Autodesk Revit Structures". Make your selections when the dialog box appears and then click "OK". Worked for me with no issues.
Thank you for your reply
yes i tried that but always got ''A Software Problem'' Pop-Up with only that Structure template
I even Tried reinstalling it Still same issue
Artur.Kosakowski
Hi @Anonymous
Have you tried to post this issue on the Revit Structure forum?
Artur Kosakowski
in reply to: Artur.Kosakowski
You could either try @Artur.Kosakowski 's suggestion or Re-install the Revit software. Personally, I've never encountered an issue like this before...
Thank you sir
i just few hours ago found the error and solution after looking it up even deeply
what i think its due to an error in the background in the installation if the software which hampers the templates
As a result you would get a 'Software Problem' Pop-up and the template list wasn't complete
To fix this error simply visit this site
https://knowledge.autodesk.com/search-result/caas/screencast/Main/Details/a07881c2-c751-459e-bf1d-50...
Then visit the one of the links at the bottom that provides installations setup for the template families
and it worked
https://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/autodesk-revi...
stilll again thanks for your reply
Artur.Kosakowski
Hi @Anonymous
Thank you for posting this information.
Artur Kosakowski
