Export/Import settings from materials, calculations...
rc_maccord
rc_maccord
Hi, I would like to know if there is a way to export/import the settings from an instance of Robot installed in one computer to another instance in a different computer. Since I'm in Brazil, I have to change quite a few things to follow brazillian code, and if I can export/import these settings, it would make my life a lot easier.
Thanks in advace!
Start off by copying the contents of your user configuration folder from the old machine to new. You can find it here:
C:\Users\<USERNAME>\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis Professional 2019\CfgUsr
For more details, please see these topics:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/creating-and-transfering-templates/m-...
https://forums.autodesk.com/t5/robot-structural-analysis-forum/user-defined-material-properties/m-p/...
If my answer solves your problem, please mark as solved. Thank You.
rc_maccord
Thanks! Worked for me.
