Export from Tekla Structures
isabel.bras
isabel.bras
When I export a model from Tekla Structures these squares appears. What does it means?autodesk.png
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @isabel.bras
This is rigid link symbol. You can check list of rigid links by Right mouse button click (on graphic screen) then Tables >Rigid links. Rigid links can be modified by Geometry >Additional attributes >Rigid links option
Krzysztof Wasik
