Execution problem no. 3060 in modal analysis
Message 1 of 10
I've modeled a power line in Robot and when I try to execute modal analysis calculations it gives me executive problem no. 3060. Had a few instabilities in some nodes, I managed to fix them but somehow I only created more instabilities. I tried some other things but it still gives me error because off executive problem no. 3060. Help please!!
Replies (9)
Message 2 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Correct model first to get rid of all instabilities in it.
If it is not the case please send us model.
Rafal Gaweda
Message 3 of 10
Message 4 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
As I said before you need to correct model first:
Rafal Gaweda
Message 5 of 10
I don't have instabilities in my structure and that error keeps appearing... I already try to repair Robot and don't solve this occurance.
My only warnings are: isolated nodes and duplicated load case.
Can I sent my file ?
Cumps
Message 6 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Yes, we need your file.
Rafal Gaweda
Message 7 of 10
Here it goes.
It's attached also the spectrum for spectral analysis.
Cumps
Message 8 of 10
The spectrum file don't have a valid extension... You can try to run the spectral analysis with any spectrum. That's certainly not the problem
Message 9 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Something is wrong with mass defintion.
You are converting loads onto masses acting in Z direction only but in Modal case definition you neglect them so in fact there is no mass for Modal.
Rafal Gaweda
Message 10 of 10
Problem Solved.
