Execution Problem 3060
Message 1 of 12
I need to perform a global buckling analysis to check if the building is sway or non-sway and I’m getting the annoying error “3060 execution problema”.
When running, the program reports type 3 instability in one node. I checked the node and corresponds to an intermediate node of a wall mesh. I regenerate the mesh for that Wall and then I still get an instability of type 3 in one node, but now it is located in a slab in another side of the building.
I steel need to perform the global buckling analysis but I don’t know what else I can do…
Link with model: https://mab.to/kOHzZrm6E
thanks in advance
AV
Replies (11)
Message 2 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
In General:
https://knowledge.autodesk.com/support/robot-structural-analysis-products/troubleshooting/caas/sfdca...
In this particular case:
- correct model to get rid of overlapping bars and incoherent meshes
- set model generation tolerance 1mm
Rafal Gaweda
Message 3 of 12
Problem Solved.
Thank you for your help..
AV
Message 4 of 12
Simau
Hi
I tried to apply  the method in the video to my meshing problem, but i can't fixe them.
I don't know which node to choose to move it in another place.
Any help for this model?
https://we.tl/jB0sLX4ww6
M. Agayr
Message 5 of 12
Simau
Sorry
here are the nodes
M. Agayr
Message 6 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
Just move some nodes to get coherent mesh
File attached.
Rafal Gaweda
Message 7 of 12
Simau
all is Ok,
Thanks so much Rafal
M. Agayr
Message 8 of 12
ledinhchinh0409
@Rafal.Gaweda
I have a "Excution Problem N0: 3060 .." error. But I cannot find the https://knowledge.autodesk.com/support/robot-structural-analysis-products/troubleshooting/caas/sfdca... -3060-durant-l-analyse-modale.html? _Ga = 2,263307530.780560046.1562227869-1524106517.1547589456. You can give me a link to help me. Thanks very much.
Message 9 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 10 of 12
ledinhchinh0409
Hi @Rafal.Gaweda
I have a structure with this error. I tried to solve it but failed. Hope you help me. Thanks very much!
Message 11 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @ledinhchinh0409
Because of lack of drilling rotation degree of freedom to prevent panels supported in one node You have to add rigid links
See:
Rafal Gaweda
Message 12 of 12
ledinhchinh0409
hi. @Rafal.Gaweda
 Thanks you very much!
Great.
Thanks for your help. I used Roman's excellent Spider Pro 1.8 tool. And successfully processed the error. . Now there's only a warning about instability 3. Can I ignore it?
