Close
Hi Rafal
Please find the attached file (Estimated fnd load). Can't ARSA calculate the load applied on the foundation? I think ARSA can calculate it correctly (Please find the attached file Estimated fnd load_1). Another question:
1- If the foundation is a circular sheaped mat foundation (e.g., foundation of circular water tank), there isn't a parameter of radius to include it in the Soil Buiding dialog.
2- If the mat foundation is irregular shaped, there isn't a contour option to include the geometry of such a shape so that ARSA can calculate K.
It does.
There is not
There is not.
Hi Rafal
It does.
Please find the attached file. Why should I estimate the load applied on foundation and put it in the field named (Estimated foundation load) while ARSA can calculate it correctly and you posted It does
There is not
But what should I do if I have a circular shaped mat foundation and you posted There is not?
There is not.
But what should I do if I have irregular shaped mat foundation and you posted There is not?
Type there estimated velue by your own of calculated reaction.
Square a=2*r ? or calculate it by your own.
Estimate it with available possibilities or caclulate it by your own.
Hi Rafal
Thanks very much for reply. What about line load? Such as loads coming from railroad.
Search the Autodesk Knowledge Network for more content.
New: Get an Activation Code
Mac OS x10.13 Support
Windows 10 Support
Autodesk Online Store Help
Software Downloads
Serial Numbers & Product Keys
Installation & Licensing
Online Activation & Registration
Network License Administration
Sign In / Create Account
Subscription Help
Maintenance Plan Help
Autodesk is a leader in 3D design, engineering and entertainment software.
