Error settings
Error settings
VillHamp
Message 1 of 17
Error settings
VillHamp
I have a problem with the icon of "typical reinforcment" in 2d fotting.
It says its a error, an unknown error. i will add a screen shot.
I tried to delete, detete all folders  and reinstall. what can it be?
Best regards,
// Vilhelm
Replies (16)
Message 2 of 17
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @VillHamp
I see that you are using Robot 2022. Have you installed Revit 2022 service pack 1 (HF1)?
Krzysztof Wasik
Message 3 of 17
VillHamp
Hi, thanks for your answer. I have 2022.0.1, and I cant find any newer update. The Robot file however were started directly in Robot.
The error is about not be able to set standard values om concrete and reinforcement in the 2d module.
Best regards,
Vilhelm
Message 4 of 17
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @VillHamp
I understand that you have Revit 2022 HF 1 installed. Problem with Robot might be related to installed HF1 for Revit.
Could you please check if in Robot 2022 Add-Ins menu you have the following options.
If only two positions are available please refer to this Robot Forum thread (message 5).
Krzysztof Wasik
Message 5 of 17
VillHamp
Hello again=), I uninstalled both and reinstalled both, now I have I later revision of revit and it dont work.
I reinstalled revit from download manager, and the file is from april realese date, can i find update of its own, from the WI-mapp folder under c:-Autodesk? Where can I find the not updated revit?
// Vilhelm
Message 6 of 17
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @VillHamp
Not updated Revit 2022 version can be installed from your Autodesk Account
Krzysztof Wasik
Message 7 of 17
VillHamp
Hi, ok thats not the same installation as the desktop app?
I will try that to, I usually download from Manage. autodesk.
//Vilhelm
Message 8 of 17
VillHamp
Do I need to delete some folders?
// Vilhelm
Message 9 of 17
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @VillHamp
I do not think any folders should be removed manually.
Krzysztof Wasik
Message 10 of 17
VillHamp
Do I need Revit 2022 to get Robot to work? I don't  have Revit installed yet and Robot still have the same problem.
// Vilhelm
Message 11 of 17
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @VillHamp
Revit 2022 is not necessary to make Robot 2022 run. Could you check Add-ins menu (see message 4 from this thread) Do you see options presented in screenshot?
Krzysztof Wasik
Message 12 of 17
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @VillHamp
One more question. After Revit 2022 uninstall have you uninstalled Robot 2022 and installed it again?
Krzysztof Wasik
Message 13 of 17
VillHamp
Hello, yes I uninstalled revit, then Robot. I installed Robot, still only 2 options. Now revit is done, version 22.0.2.392, from manage.autodesk.com. no additional installations.
// Vilhelm
Message 14 of 17
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @VillHamp
I am registering your issue in Developers Problem Databases. Ticket number RSA-38366. Since service pack for Robot 2022 will be released, switch back to Robot 2021.
Krzysztof Wasik
Message 15 of 17
VillHamp
Hi, ok thanks. I hade problems some time ago with 2021, integration revit-robot. I ended up reinstall, hard reset, of windows, and wiped it clean... Maby not this time then...=). I have I project running and started, I guess it´s not possibly to go back.
Thanks!
Sincerely,
// Vilhelm
Message 16 of 17
VillHamp
But how can the hotfix have a lover number then I have now?
// Vilhelm
Message 17 of 17
VillHamp
Hello again, do not care about my last question, I noticed now that hotfix kicks it up to 22.0.10.xyz, thats higer the20.0..2.xyz...
Have a nice day!
// Vilhelm
