Error "Incorrect Data - Error Nr. 5000" in RSA 2023
Cestakar
Cestakar
Hi!
I get during seismic analyses according to Eurocode 8 error - "Incorrect Data - Error Nr. 5000". I am using Autodesk Robot Structural Analyses PRO 2023.
I have no more ideas, what can be wrong? Can you please help me? I attached my file.
Thank you very much. Regars!
Accepted solutions (3)
Stephane.kapetanovic
hi @Cestakar
https://forums.autodesk.com/t5/robot-structural-analysis-forum/incorrect-data-error-nr-5000/td-p/331...
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
okapawal
Hi @Cestakar
In your seismic load cases you set the Range of Seismic Load.
But for some reason the top story value is empty.
This  brings issues with the base shear load distribution and ends up with this error.
You need to set the top story value.
When I set it to Story 6, everything is going well.
Waldemar Okapa
Sr Product Owner
Cestakar
Thank you very much okapawal! It's working. 🙂
