Error message hidden
When you run a calculation error messages usually pops up:
However if you run a calculation and you have clicked on another application in a meantime, than (sometimes) when calculation error pops up, you are not able to see it and click YES (you can see the big dialog window only) and therefore the only way to carry on is to kill Robot in Task manager and start again.
Is there any chance to have it always on top of all Robot windows?
You can see in desktop preview that the window is there but I cannot find a way ho to have it on top of Robot.
mustafahesenow
Hi @Anonymous
To avoid killing RSA You could try this
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Doesn't help. Still the same issue. Little dialog box is not visible.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Try to press 'ALT+F4' and then answer No for the question about closing Robot. This should (hopefully) bring the message box to the front.
Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
As I just got the same situation - what helped was clicking on the Calculation dialog so that it was active and then pressing the Enter key.
Artur Kosakowski
Alt F4 works
