Error: Ar/At=0<1
Error: Ar/At=0<1
Error: Ar/At=0<1
I am calculating a circular RC cover slab for a chamber with 2 big access openings. when i was calculating the provided reinforcement i got a messenger like "For top/Bottom reinforcement in the direction of X or Y axis at the point Ar/At=0<1"
I tried to solved doing the steps that appear in the following link but i couldn't make it works.
https://knowledge.autodesk.com/support/robot-structural-analysis-products/troubleshooting/caas/sfdca...
Could someone help me with this problem?
Kind regards,
Kevin Varela.
I am calculating a circular RC cover slab for a chamber with 2 big access openings. when i was calculating the provided reinforcement i got a messenger like "For top/Bottom reinforcement in the direction of X or Y axis at the point Ar/At=0<1" I tried to solved doing the steps that appear in the following link but i couldn't make it works. https://knowledge.autodesk.com/support/robot-structural-analysis-products/troubleshooting/caas/sfdca...
Thanks,  Kind regards, Kevin Varela
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
The rtd file you attached is corrupted (check its size). Could you attach it again?
Artur Kosakowski
