Error 101
Error 101
Error 101
Problem: I have developed an error 101 after some edits with my model.
Original Model: a 22m x 10m canopy supported by cable system.
Changes made: I deleted the truss elements of the model and have added panel loads.
Questions:
1) What does error 101 refer to?
2) Are there a catalogue of errors and descriptions that I can refer to?
3) Does robot give you more information on how the error has developed apart from the window?
Romanich
Hi @Anonymous,
List of errors:
http://help.autodesk.com/view/RSAPRO/2018/ENU/?guid=GUID-8E8ED7A4-9A55-4F1F-8771-7E1A9CEF73B2
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Open the file in the repair mode following the steps described in this article.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
However, it has deleted some of the members in the repaired format
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
This would indicate that corresponding data got corrupted hence the wrong (most likely 0) node number. You need to redefine them Smiley Sad
Artur Kosakowski
