Elastic Release
Elastic Release
e2009355
Message 1 of 10
Elastic Release
e2009355
I'm modelling simple frame symmetry (Rc Column with steel rafter) in Autodesk Robot Structural analysis 2012with two cases. - column fix 100% with rafter (00000A1) - column fix 20% with rafter (0000A2) The result is, first case, moment is symmetry, but other case is not symmetry. Why? What's wrong? No wind load!! Model is symmetry!!!
Replies (9)
Message 2 of 10
e2009355
Message 3 of 10
e2009355
i cannot import picture!!!
Message 4 of 10
napooil
You will should attach file .
Message 5 of 10
e2009355
i cannot attache file!!
Message 6 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 7 of 10
e2009355
No, I cannot attache file even image (260kb) !!!
Message 8 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
Make sure you have signed in first.
Artur Kosakowski
Message 9 of 10
e2009355
Yes, already signed.before i can, but now i cannot !
Message 10 of 10
napooil
Not look problem.ASRP2016
