Effective Area in Design of Tension Area
tmujtaba78
tmujtaba78
Hey,
I have been trying to reproduce design examples from AISC on RSA. I have noticed a issue in Check for tension. The problem is that efficetive area is not modified. Member defination is as per shown below.
The type is defined as shown
Now when i do the code check in fact these parameters are updated but effective area does not chnage infact it should deacrease as effective area is Ae = An x U and where An = Red. factor x Ag. But these are the resuts that i recieve.
CaioSaporito
Hi @tmujtaba78 !
Which version do you use?
In 2023 and 2024 it´s ok for me:
Try to create another "code parameters", with a new name and apply to your beam again.
Best Regards,
Caio
tmujtaba78
I am working with 2022 version, but i will try and let you know by redifing the element
