Edit - Correct Deforms Panel Geometry
SerhanB
SerhanB
I'm working on a Robot model which is transfered from Revit. Before meshing I'd like to merge nodes in Robot with Edit-Correct tool. I choose entire model and untick bar intersections and geometrical center options with precision 0.01m. The process takes more than an hour and resultant shape of the panel at level +9,83 is distorted. Can you take a look and tell me why this is happening. Thank you very much for your helps.
Serhan BAKIR
http://www.stand.com.tr/
Rafal.Gaweda
Autodesk Support
Autodesk Support
With 1m mesh ~220000 nodes are generated. Correction reduces them to 120000 so it may take a while
It has just partially lost interior display, nothing more. I am investigating it
Rafal Gaweda
Rafal.Gaweda
Autodesk Support
Autodesk Support
in v 2014:
- correction lasts some minutes
- display correct
Rafal Gaweda
SerhanB
Thank you Mr. Rafal I will consider that.
Serhan BAKIR
