Ad1: 5.4.3.2.2(12)P – Robot uses provisiond of EN1992-1-1:2004 which is allowed for 0.2<q<2.0
Ad2:
5.4.1.2.2 Columns (EN 1998-1:2004)
(1) Unless q<=0,1 (see 4.4.2.2(2)), the cross-sectional dimensions of primary
seismic columns should not be smaller than one tenth of the larger distance between the
point of contraflexure and the ends of the column, for bending within a plane parallel to
the column dimension considered.
4.4.2.2 – znajdziemy w EN 1998-1:2004
The linear analysis can be used for q <= 0,1
Ad3:
5.4.3.2.2 Detailing of primary seismic columns for local ductility
(4) In the absence of more precise information, the length of the critical region lcr (in
metres) may be computed from the following expression:
lcr = max{hc ; lcl / 6; 0,45}(5.14)
where
hc is the largest cross-sectional dimension of the column (in metres); and
lcl is the clear length of the column (in metres).
Artur Kosakowski
