EC2 and EC8 design requirements covered by Robot
Μηχανικος
Μηχανικος
Hello everyone,
I am in the process of designing a RC structure; i have the analysis results and i have also carried out the provided reinforcment calculation for the columns of the structure.
So Is there a way to check all the clauses of EC2 and EC8 that my design complies with?
Basically i want to know if robot covers all the required clauses of EC2 and EC8 when carrying out the design, and if not i want to know which clauses are not covered.
Thank you
Μηχανικος
Other than the report note in the provided reinforcment module is there any other way to view all the EC2 and EC8 checkings carried out by robot?
Μηχανικος
http://knowledge.autodesk.com/support/robot-structural-analysis-products/learn-explore/caas/document...
EN 1992-1-1 2004 - Use Limitations
Apr 21 2011
The following sections of EN 1992-1-1 2004 are not verified in any RC design module.
2.5 Design assisted by testing
2.7 Requirements for fastenings
3.1.5. Stress-strain relations for non-linear structural analysis
3.1.9 Confined concrete
3.2.6. Fatigue
3.3 Prestressing steel
3.4 Prestressing devices
5.6 Plastic analysis
5.7 Non-linear analysis
5.8.3.3 Global second order effects In buildings
5.8.6 General method
5.9 Lateral instability of slender beams
5.10 Prestressed members and structures
6.2.5 Shear at the interface between concretes cast at different times
6.3.3 Warping torsion
6.5 Design with strut and tie models
6.7 Partially loaded areas
8.7.3 Lap length
8.7.4 Transverse reinforcement in the lap zone
8.9 Bundled bars
8.10 Prestressing tendons
9.6 Walls
9.9 Regions with discontinuity in geometry or action
9.10 Tying systems
10 Additional rules for precast concrete elements and structures (except 10.9.6 Pocket foundations)
11 Lightweight aggregated concrete structures
12 Plain and lightly reinforced concrete structures
Annexes
F Reinforcement expressions for in-plane stress conditions
G.2 Piled foundations
H Global second order effects in structures
I Analysis of flat slabs and shear walls
J.2 Frame corners
J.3 Corbels.
Some of them maybe now are enable for ec2. The link is reffered in 2011
