double problem with trus bars only tension or only compression
Michele100100
Michele100100
Hello everyone,
after run my calculation I have 1 error and 1 warning:
 1) INCORRECT USE OF RELEASE FOR TRUS MEMBER:
2)
it's my first time using only compression/only tension bars.
Attached my model.
Rafacascudo
you cannot have releases on truss bars . They are already full released bars .
If you want them to be tension or compression only bars and also have them supporting other forces as in your "Lashing" release type , then you have to forget truss bars and use regular bars with unidirectional releases in the Ux direction.
Rafael Medeiros
Michele100100
thanks.
