Distorted Element issue
tt501613
Message 1 of 8
tt501613
When I try to load a concrete wall with a hydrostatic load I get a distorted element error and Robot will not run.  The screen shots below show what I get.  The wall  is not restrained at the top but is along the other edges.  I have tried several different kinds of restraints with no luck.  Help.
TT
Replies (7)
Message 2 of 8
Rafacascudo
Distorted element waring shows a problem with FE mesh . Click on the waring and it will probably highlight where the problem is
Rafael Medeiros
Message 3 of 8
tt501613
Message 4 of 8
Rafacascudo
zip and attach the model ,if possible
Rafael Medeiros
Message 5 of 8
tt501613
Thanks for your help on this.
Attached is the file.
TT
Message 6 of 8
Rafacascudo
your model is done on "plate" strucuture type and has no loads or supports.
Use "shell" structure type and it shall work with no problems
Rafael Medeiros
Message 7 of 8
tt501613
Still having problems...obviously I am new at running Robot.  Thanks again for your help.  See attached for my latest try.  Interestingly, I noticed I get a deflection on the pressure side of the wall, however still no results.
TT
Message 8 of 8
Rafacascudo
the only problem on your model is that your chosen thickness (TH6.00) is an orthotropic type and the orthotropy direction is perpendicular to the panel plane , which is an error.
I don´t see a reason to use that type of orthotropy with 0.999998 factor for all stiffness terms , but this is your problem.
Using an isotropic wall or orthotropic with correct orthotropy direction will solve all your problems
Rafael Medeiros
