Dissapearing walls, when sending the model from Revit to Robot
Message 1 of 9
Hello gentleman,
I am a newbie with Robot, so be easy on me lol
I did a model in Revit, ( structure concrete ), no steel structure at all,
And yes some columns do have errors which i have to fix yet, but my question is the plan and simple concrete floor ,
Any advice what to do inside of Robots ?
or is it options before sending ?
Attached screen shots showing, floors from fort floor till the 12th doeskin appear in Robot !
any help would be appreciated, but please, easy when you explain to me lol
Replies (8)
Message 2 of 9
Ok, i took the model to Navisworks, to test it , and the same floors didn't appear, so i am guessing something is wrong with those floor, ( even tho i made sure i created them as Structure Floor and they have the option of (Structural) on.
Message 3 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Assuming it is the same for a single floor from your model could you attach such Revit file?
Artur Kosakowski
Message 4 of 9
Hello @Artur.Kosakowski
I will upload both files if you want, the revit and the Robot one, but i am still trying to figure why those specific floors dont show in Revit Analytical model too ! but i am not at the office at the moment, so as soon as i am at the office i will upload it and tag your name so you get an email, thank you sir
Message 5 of 9
mustafahesenow
Hi @Anonymous
In Revit File be sure that this wall are structural walls and they have analytical system then for sure it will be transfer to Robot.
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Message 6 of 9
@mustafahesenow, Dear Eng,
kindly check the attached images i had with my question, as i highlighted that they are already are structure floors 🙂
Message 7 of 9
BenzyMH
Hello everyone
I found the solution why they weren't showing in Revit Analytical nither in Robot,
The reason was , when i designed the slab i drew the openings of the slab with the same floor creation tool,  Picture available,
instead i deleted them as shown, and i use the Revit Shaft opening option, and it worked,
So i am guessing , Robot has something to do with the floor creation method, and it does understand the ( Shaft ) opening better than the normal old fashion way,
Images posted
My System Info
Manufacturer Hewlett-Packard
Model HP Z800 Workstation
Total amount of system memory 24.0 GB RAM
System type 64-bit operating system
Number of processor cores 6
My Graphic Card Info
Display adapter type NVIDIA Quadro 2000
Total available graphics memory 13047 MB
Dedicated graphics memory 1024 MB
Dedicated system memory 0 MB
Shared system memory 12023 MB
Display adapter driver version 9.18.13.2078
Primary monitor resolution 1920x1080
Secondary monitor resolution 1920x1080
DirectX version DirectX 10
Message 8 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @BenzyMH
Thank you for posting the solution. Indeed if you can't see an object in Revit Analytical model display it will not be transferred to Robot too.
Artur Kosakowski
Message 9 of 9
BenzyMH
@Artur.Kosakowski, Yes sir that's what i learned 🙂
Thanks for your help tho 🙂
My System Info
